typical procedure in my workshops (Specialized Covent Garden, Sigma Sport, Specialized Kingston, Giant Docklands):
-carbon head tube with carbon seats would be wiped clean with iso alcohol and bearing placed directly onto the CF seats.
Any metal parts fitted above or below the bearings (compression wedge ring for upper, and crown race for lower) would get a thin smear of Shimano anti-seize
-carbon head tube with aluminium alloy cups / seats would be wiped clean also with iso alcohol and then a good smear of Shimano anti-seize between the seat and the metal bearings, and also on the metal parts fitted above or below the metal bearings.
we only use carbon fibre assembly paste for CF seat posts, CF handlebar stems / CF bars or similar applications. Certainly not where a bearing is rotating.
