I bought the proper kit for my van to get the anti-sway control etc. Also the dash now tells me if the trailer lights are faulty. And you dont need nasty crimps on your cars wiring loom.
I’ve since tried to use a relay ‘aka bypass relay’ to switch on an additional reverse ‘floodlight’ lamp on the back of the van, the electrics are so bloody sensitive it throws up bulb failure warnings whether I connect it to the trailer electrics loom, or the normal van wiring loom. I don’t know how it can detect a 40mA relay when its also operating a couple of 21w reverse lamps, but it does. So its getting wired to a manual switch instead.
On the flip side, our Honda switches off the reverse sensors with a basic bypass relay, not sure if its a time switch after 10 seconds, or if it just works out you are still reversing and haven’t yet hit anything!
I’d find the OEM kit on ebay, I bet its not £220 (plus the deleted cost of the basic bypass relay). It’ll probably just be a plug, some wires and the socket, that plugs straight into a socket somewhere on the car.
