It’s likely that the ‘uneven’ wear is due to camber. In your case, it would be negative camber. Most cars nowadays do not allow for any adjustments to camber angle, so it will be something you’ll have to live with, unless of course there is an eccentric bolt (typically) on the lower part of the front suspension strut.
You’ll notice this wear particularly if you do many motorway miles as the negative camber gives the wheel/tyre a top-in stance when looked at from in front or behind (check the open wheel F1 cars for more aggressive angles). Effectively, the negative camber enables a fuller contact patch with the road surface when cornering and therefore, better grip.
It would also be worth having the tracking checked btw just incase.
Hope that helps
