I have decided to put this on here because the Mazda forum is so utterly garbage and I have never had a single response to any of my questions. My car is used almost entirely for bike transportation purposes so I believe its relevant enough.
I also know that you lot are far brighter than any of those petrol head monkeys….so here goes
****2005 Mazda 6 Diesel estate 2L, 130,000m ******
I finally got my car back together yesterday having changed out some broken rockers after a Cam belt failure. The car was essentially scrap so I figured I couldn’t make it any worse by having a go. Quite unbelievably the engine started first time and runs smoothly.
Slightly annoyingly there is a grinding sound coming from the power steering assembly – which gets louder and more pronounced when I turn the wheels (Steering seems to work fine). I am worried because I had to remove this assembly to get to the rocker shaft; including removing the Vacuum pump, housings. and drive cog all the way back to the crank shaft.
The sounds worryingly like cogs grinding but I just cant see how I could have screwed this bit up!
The transmission fluid is well below the minimum level (just above the bottom of the reservoir). I’m not sure why as I don’t think I interfered with that system. The fluid also has air in it as bubbles appear in the reservoir after turning the wheels.
Clearly I need to top up the fluid and do a few full locks to remove the air but I’m worried that this could be a red herring; and I don’t want to continue to grind up my gears if their is in fact another problem.
So – can low levels of steering fluid create a grinding noise??
Also – will I be OK to top up the reservoir with Castrol ATF Dex II Multivehicle?
this is what the shop manual says but I dont want to mix incomparable fluids. The fluid currently in there looks clear or maybe greenish – what color is the Dex?
Is it OK to top up or should I replace all the fluid – it looks to be in good condition.
