My car has started “jerking” when going on and off the throttle – ie if I clutch in at low revs in 1st then accelerate I get a big jerk as it revs up. I get a similar problem when changing gear – if I lift off when changing up (as normal practice) I then get a jerk when putting my foot on the accelerator again – the only way to avoid this is to spool the engine up and slip the clutch on each gear change. Also a jerk when lifting off – if I lift off the accelerator and then touch the accelerator again I get two “jerks”!
It’s a turbo diesel, so wondering if it’s something to do with the turbo – power and economy seems OK otherwise though. Is also getting on a bit – almost 150k miles and not worth a lot, hence reluctant to spend much on it (if the estimate to fix is >£500 I’ll be putting up with the problem until I scrap it, so no point in even paying to get it diagnosed in that case).
Thanks for any help.
