anyone got any thoughts please ?
Old BMW E39, fwiw
had a towbar fitted about 3yr ago, pushfit connectors (ie cheapo) but worked fine for 2yr +
now I get an intermittent fault on the dashboard alert thingy, suggesting that one or sometimes both rear brake lights are out. it used to be a total lie and both would still work, and driving for a bit would make the warning lights go out. now the LHS light is on permamnently and the brake light really isn’t working (bulb is OK) any of the time. Still get right side warning light coming on – still intermittently only.
If I plug a lightboard into the towbar socket, the lightbar brake lights do come on and dashboard warning lights don’t alter.
Have checked for loose connections as best I can & none found. no obvious corrosion at sockets
so then, WTF ?!
