My car has started having trouble starting – it started just over a week ago and has gradually got worse. I’m thinking it’s the battery, but just after confirmation it can’t be anything else.
It’s usually quite laboured turning over, though sometimes turns over fine. Sometimes the solenoid clicks and nothing happens, but when I try again it does kick in and turn over (usually quite slowly). I presume as the starter motor is turning it’s not that?
Battery voltage is all over the place – 12.9V straight after turning off the engine, but then dropping down to 12.2V after a few hours. It was down to 12.15V earlier after trying the headlights with the engine off (~11.9V with headlights on). I disconnected the battery it was 12.4V at terminals, then 12.15V as soon as I connected it again.
It seems like a knackered battery, or do I have something else wrong with my electrics? (I’m just slightly suspicious because all suggestions are that my battery voltage should be lower if it’s dead, and the variability with how well the engine turns over – just now it started as if nothing was wrong, turned it off tried again and just got a solenoid click).
