Disagree about trying to move it a bit. The tyres will be fine, especially with such a light car, and as it was just serviced the pressures will be fine.
It may be worth starting, but make sure you run it until it at least reaches normal operating temp so that you have removed all traces of water vapour from the cylinders and exhaust. DO NOT let it idle during this time as
a) it will not recharge the battery from the effort of the cold start
b) oil pressure is very low at idle, so letting it idle for any period with the engine cold is the quickest way to damage it
Keeping it at about 1500 rpm (say 1/4 throttle) until hot should do the trick
