Kryton57 – Member
I’m looking at the XC 9.0. For the money its stupidly light (dripping in XO), and has all the “right” angles.
I’m testing an EX8 next weekend, and am thinking that the DRCV (well, at least what the reviews say it does) will suit – ie replicate short travel at the beginning of the stroke, then open up later – presumably outweight the soft back end issue of the Canyon you speak of.
When you test the EX8, make sure you get the shock set-up correctly. I demo’d a Stumpjumper FSR Expert and an EX9 (both 2010). The FSR just rode nicely without any tinkering, whereas we tried all day and just could’t get the rear end of the EX9 to feel right. It felt really harsh over terrain that the FSR just soaked up. It wasn’t due to the EX9 being a shorter travel bike than the FSR either, as my mate was on his Whyte E-120 which has the same travel as the EX9, but felt much better over the same terrain.
I was told after that we might not have put the shock pump onto the shock correctly. Apparently you screw it on until it registers a pressure and then keep going to open up the DRCV valve. If you don’t do this, you are only pressurising the small air chamber, and then presumably as soon as the valve opens, it equalizes the pressures meaning you are running too little air.
Thing is with this explanation, I would expect it to result in the rear suspension being way too soft once the shock had fully opened once, but this wasn’t the case.
