Same issue here on a Nerve AM 2012 ….managed to get the rear triangle apart including the spherical BB bearings .I had previously used Loctite 243 on all linkage bolts and when I came to disassemble the BB spherical bearing was stuck to the bolt so it came out fused to the bolt!
Any help with the below would be appreciated.
Rocker arm bearings changed large 608’s …used the superstar tool no issues
Rocker arm small bearing 626’s I think….changed using sockets / bolts no issues
chainstay bearings near the QR will not move 2 are sat side by side with a spacer between them. I understand there is an internal lip also which means they can’t be pushed through …..tried an 8mm blind bearing puller and I’ve broken the collet! Tried a punch after moving the spacer to the side and catching the lip of the inner race used a mallet rather than a hammer though so I may not have given it a big enough whack….. advice appreciated.
I have 1 spherical bearing stuck in the chainstay ….. any advice on tools used to remove this bearings and then the method you used to re-assemble would again be appreciated.
Wayne
