Its the actual canvas threads showing through, I dont think I run the pressures too low, generally around 35psi, I use the same pressure front and rear, but its only the rear that have the canvas showing.
I did consider it might be a rock scrape, but its pretty even around the whole sidewall and on both sides, so I dont think it is due to rock scrape.
Mud rubbing the tyres sounds the most likely candidate, but I’ve never noticed this on any other tyres.
Will probably run them tomorrow and then replace with some specialized eskars, too late to change for tomorrow.
Its a shame as up until now I thought they were pretty good tyres, but expensive. If the sidewall is going to be the weakspot and fail after not that much use I might as well get something thats 90% as good but 50% of the cost.
