You can get adaptors (i’d try for a second hand one) that increase the focal length, but these take additional time to fit and remove.
Is she shooting full frame? Assuming so, then the only real option is the Canon EF 70-200mm f/2.8L USM, with a second hand extension tube. The lens can be had within the uk for under 1K. That said, if she pops down to a pro retailer and tries out the costly IS version, she won’t want anything else, that thing is pin sharp.
Stick with canon glass btw, full on focus compatibility, weather sealing etc.. is worth it. IS is great for hand held, no tripod needed.
Beyond that, look at a better body, with cleaner, higher iso and try the F4 IS at far less cost.
If she’s shooting cropped, then A, she’ll end up full (nr full) frame in the future if she sticks with it and B, she’ll have the extra magnification via the crop factor, so this model is still a good choice.
End of the day, don’t skimp on the glass, there’s a reason why it’s so expensive.
