Viewing 4 posts - 1 through 4 (of 4 total)
  • Cane creek DB air – air leak from positive to negative air chamber??
  • portydave
    Hi, as above. My shock is sitting really low in its travel with my usual air pressure and won’t return to its full length, and when I let all the air out it retracts fully, so seems like I have air migrating to the negative air chamber?
    Anyone had this happen before, and how do I fix it? DIY….or do I need to send it off?
    julians
    Yep, I had this. You need to send your shock off for a rebuild, its knackered.
    Sorry to be the bearer of bad news.
    portydave
    Bummer…..cheers though!
    Did you just send it to TF tuned for a standard type service…..or something special??
    julians
    I sent it to tf, just told them it was sticking down. They sorted it out.but it cost 140 quid.
    It needed a new damper shaft,seals etc.
The topic ‘Cane creek DB air – air leak from positive to negative air chamber??’ is closed to new replies.
