I was wondering whether there was some reason why 120mm wouldn’t help (temporarily, for climbing) with these slacker frames
Lowering the front travel will also lower the bottom bracket and its already pretty low on the rocket as it is.
I find the method of determining optimum shock pressure is by setting it at 30% sag then adding a bit on the trail to minimise pedal strike i.e. when you no longer strike you’ve got it 😀
Having taken a Rocket up the Firmounth climb at Glen Tanar (which I think is about 500m difference in elevation and, hence, takes a fair while) I never once thought I wanted the front lower. It climbs much better than a Soda at 100mm! (IME obviously). Now I’m not saying that I managed to cycle it all the way but I’ve got as far up as any bike I’ve ridden on it over the years. So I’d say it was really, really good climbingwise.
just my 0.02 worth.
