Viewing 34 posts - 1 through 34 (of 34 total)
  • can you use a 22mm pipe cutter to cut down bars?
  • porter_jamie
    http://www.screwfix.com/p/rothenberger-automatic-tube-cutter-22mm/24477
    this kind of thing?
    i need to narrow the bars on my wifes roadrat, they need about 20mm off each end. i could hack saw it but maybe this would make a neater job of it
    steve_b77
    Just hacksaw & file
    stevied
    Yep, I’ve got a similar thing. Can pop it in the post if you want to borrow, save buying one?
    porter_jamie
    Oh thanks. Next door neighbour has one though!
    trail_rat
    there is less remedial work needed if you hacksaw. the razor sharp lip left by pipe cutters need filing both inside and out . if you hacksaw you barely need to touch it .
    that said given most people cant hacksaw in a straight line to save them selve you might want to get a pipe cutter and put up with the extra filing time.
    honourablegeorge
    I use this style of cutter for fork steerers and seatposts, nevr cut a set of bars (always found wider to be better) but should work fine
    http://www.screwfix.com/p/rothenberger-no-35-telescopic-tube-cutter-6-35mm/61463
    spooky_b329
    Hacksaw.
    You’ll just blunt the pipe cutter, and the rollers will mark the bars. Been there, done that.
    RustyMac
    As per pretty much everyone else.
    Blunted a telescopic pipe cutter doing some bars – hacksaw was a quicker solution.
    simons_nicolai-uk
    That pipe cutter is £45. A cutting guide for fork steerers is only £16 (Link)
    I can’t cut straight so use it for bars as well. Sharp hacksaw, tidy up with a file.
    porter_jamie
    Right. Measure twice and all that I’ll stick them unwanted end first in the band saw
    honourablegeorge
    simons_nicolai-uk – Member
    Wow, it is. I have two of them, somehow, and I didn’t pay for either of them. Someone just left them in my shed.
    Cheaper version here
    http://www.screwfix.com/p/rothenberger-minicut-2-pro-tube-cutter-6-22mm/71782
    Bez
    Should we just double check that we’re talking aluminium and not carbon here…? 🙂
    chrismac
    I did. Much neater and more accurate than using a saw. Didnt need any filing after as the cutter left a chamfered edge
    Rio
    Pipe cutter is quicker and leaves a neater outside edge, and usually includes a deburring tool to remove any residual internal lip if you want. Hacksaw requires guides and files. Either will work.
    Moses
    I’ve used one, much neater and easier than a hacksaw. I only paid a few quid for mine, nothing like £45.
    phil56
    I use two old lock-ons from grips ‘back to back’ as a saw guide – seems to work fine
    patriotpro
    this kind of thing?
    I used one of those. It works but had to do too much ‘making good’ with a file to make the saving worthwhile as the cutting wheel isn’t good enough for the task (it’s meant for copper piping at the end of the day).
    My advice is to use a cutting guide and saw.
    patriotpro
    phil56 – Member
    ‘Like’
    trail_rat
    no it doesnt. maybe if it was 7″ OD
    top tip. dont force the blade and try to rush it,
    Rubber_Buccaneer
    trail_rat is right about this. I always use a pipe cutter on aluminium because it gives a nice straight cut. Then when I’m filing off the lip it has left I think to myself that I should have just used the hacksaw and taken a bit of care 🙂
    simons_nicolai-uk
    Like that as well. Using a saw to cut straight is easy if you can do it, very hard if you can’t
    mattsccm
    Reminds me that a mate was proudly telling me that he bought a guide and special saw to cut down the steering column on his carbon forks. 😆 🙄
    Pillock!
    steve_b77
    Rio – Member
    How rubbish are you with a hacksaw 😯
    5plusn8
    Me, terrible, did a couple of fork tubes and always wander off, looked like it was cut with a snow plough. I think it is my soft office workers hands.
    However I am not really an advocate of using the pipe cutters either as they cause a little raised up bump at the cut, increasing the diameter so the headset wont go on. My last forks where I used a posh pipe cutter I spent ages filing this down.
    My genius solution? Use a hacksaw, but find someone who knows how to use it…
    trail_rat
    you did put the steerer in a vice right or were you trying to cut it on the floor secured between your feet ?
    5plusn8
    Clamped to bench with home made wooden v blocks, held down with diy quick clamps. It was straight and level and secure. I confess to it being an issue with the hacksaw pilot.
    I have since googled it and despite following instructions I am still rubbish. I believe it is an experience thing, like plastering, seems easy, bloody hard to do unless you have lots of practise.
    trail_rat
    How do you get to Carnegie hall dougal ?
    5plusn8
    Practice. Exactly…
    (although I can’t decide is it practise or practice http://www.future-perfect.co.uk/grammar-tip/is-it-practise-or-practice/)
    bencooper
    Pah, you lot are amateurs – I’ve just bought one of these:
    [video]https://www.youtube.com/watch?v=NYV8yIQ9AV0[/video]
    trail_rat
    Fly as **** that
    molgrips
    As above – the pipe cutter doesn’t remove material, it just squishes its way through the metal, causing a lip each side of the groove which is quite hard to file off perfectly.
    I use pipe cutters to score it, then get the hacksaw and make shallow cuts in the groove all around. So cut shallow groove, rotate, groove, rotate, groove and so on until through.
    Don’t try and be a hero and just saw straight. The cost of failure is too great. Use your brain not your ego and come up with a foolproof method 🙂
    joshvegas
    Ben i thought you had a motorhacksaw?
    bencooper
    That stopped working and I haven’t bothered fixing it because it was very slow anyway. For cutting tubes I mostly use either one of these:
    Or one of these with a cutting guide:
    But for some processes I’ve been using a hand tube cutter and I thought a powered one might speed things up.
    Still looking for the best tube deburring solution, however.
The topic ‘can you use a 22mm pipe cutter to cut down bars?’ is closed to new replies.
