Viewing 8 posts - 1 through 8 (of 8 total)
  • can you run normal v brakes on a roadrat?
  • fontmoss
    um as above
    16stonepig
    Yes.
    4ndyB
    yes
    swamp_boy
    Yes,
    Had a test ride on an Alfine equipped one yesterday and it had Vs as standard.
    fontmoss
    yeah thought so but just put some on and the arms seem very splayed, ill have a shower and see if i wake up then try again
    Onzadog
    Swap the pad spaces around.
    fontmoss
    good plan!
    Seamus
    Standard Vs were very wide on mine(avids). I contacted Cotic as I thought I was doing something wrong and the answer was basically use shimano and they would be okay. Changed to mini vs in the end as they looked neater and plenty powerful enough.
The topic ‘can you run normal v brakes on a roadrat?’ is closed to new replies.
