Viewing 2 posts - 1 through 2 (of 2 total)
  • Can you remove chainstay protector on a 2016 Orbea Occam?
  • Special_ized_Jamie
    Fitting an invisiframe kit and chainstay protector needs to be removed to be fitted correctly. No obvious way to remove as far as I can see. Any ideas?
    Special_ized_Jamie
    Simple answer, yes you can just takes a bit of force, not sure how many times I’d like to take it off and on as needs some bending to make it shift.
    However lots of grime behind it so good idea to remove and clean. Think I’ll roll am inner tube over the top as well
The topic ‘Can you remove chainstay protector on a 2016 Orbea Occam?’ is closed to new replies.
