Had a bits box clearout this morning and will be putting some retro stuff on Eblag this evening.
One of the bits was a brake rotor, looking a little scratched where somebody attacked a couple of the mounting bolts. I have no idea how it came into my possession though I think it could have been when I bought a pair of Hope brakes off the web about 15 years ago, which turned out to be sadly neglected; I think the rotor came with them which makes me think it might be an early Hope rotor.
The diameter is 165mm and as far as I can make out the BCD is 84mm. Googling doesn’t throw anything up at all – are these standard sizes?
Singlespeed_Shep – Member
looks like an old hope big un, but could be wrong
POSTED 9 MINUTES AGO # REPORT-POST
Certainly the old Hope 5-bolt pattern, so would direct mount into a Big Un or would use a carrier to mount the likes of an XC/Sport/BULB (BULB had a different spline to the other two though).
Would work with Hope mechanical or with the old closed system brakes or with early open ones (“O2’s”)
Won’t be for a Mechanical, they were 155mm as far as I remember (think type 1 hydraulics were too), it’ll be for C/02 5 bolt IS systems, but will work on Minis too (with reduced squealing if my experience is anything to go by).
Posted 10 years ago
Viewing 7 posts - 1 through 7 (of 7 total)
The topic ‘Can you identify this brake rotor for me?’ is closed to new replies.
