Viewing 7 posts - 1 through 7 (of 7 total)
  • Can you convert a Pro Evo 2 20mm to qr?
  • inthehouse
    Hi guys,
    Can you do the above,im new to mtb so your help would be appreciated,i know there is conversion kits for qr/20mm,but wanted to know if it can be reversed,
    Thanks in advance 🙂
    Northwind
    Absolutely, it’s just a case of changing the end caps, takes a couple of minutes.
    wavejumper
    Yes. Adapter required.
    reggiegasket
    I have some QR ends if you need them.
    jonba
    Trailseeker
    I’ve got some QR adapters if you fancy a straight swap – email in profile
    inthehouse
    Thanks alot,seems like its common knowledge,
    reggiegasket,Trailseeker il keep you posted on that,
    CHEERS.
The topic ‘Can you convert a Pro Evo 2 20mm to qr?’ is closed to new replies.
