Viewing 6 posts - 1 through 6 (of 6 total)
  • Can I use DOT4 instead of DOT3/4 brake oil???
  • tacopowell
    First time bleeding my Clark S2 brakes,
    Officially uses DOT3/4
    But would it have any problems using DOT4?
    I’ve never heard of DOT3/4.
    I think “DOT3/4” means DOT3 or DOT4.
    So, yes, you can use DOT4
    JAG
    Yes – they’re very similar and directly compatible.
    tacopowell
    MidlandTrailquestsGraham – Member
    Did think this but I did find a couple of bottles of 3/4 via google,
    However on further search they actually say 3&4,
    Note to myself…..look harder before asking stoopid questions! 😳
    Cheers for the help! 😀
    ruscle
    Yes you can the only difference is their ‘wet’ boiling point ie how well they work under high temperatures.
    tacopowell
    aaaahhhhhh!!! 😉
The topic ‘Can I use DOT4 instead of DOT3/4 brake oil???’ is closed to new replies.
