Viewing 7 posts - 1 through 7 (of 7 total)
  • Can I use a shimano rear mech with sram shifters?
  • gtkid
    I know the sram shifters are 1:1 but as the mech just moves as the shifter dictates is there any reason this won’t work?
    Stoner
    the actuation ratio must match between shifter and mech.
    You can use SRAM Attack shifters with shimano mechs but not the numbered ones (X9, X0)
    If the shifter has a name (Attack, Rocket etc) – yes
    If it has a number – no
    rockthreegozy
    Yes, mech is designed to work with the same pull ratio as the shifters, so change one and things don’t tie up.
    Unless you have SRAM attack/rocket shifters, its a no-go.
    Front mech will work with SRAM or Shimano shifters.
    gtkid
    OK. thanks. Shifters are Sram X7 so that’s a no then. Cheers.
    Junkyard
    have a functional but battered x7 rear mech if required – click on my name to e-mail me
    gtkid
    junkyard ygm
The topic ‘Can I use a shimano rear mech with sram shifters?’ is closed to new replies.
