Viewing 6 posts - 1 through 6 (of 6 total)
  • Can I reduce travel on a pair of 2010 RS Rev's Dual Air?
  • BigBoyXC
    Bought 150mm travel Rev’s for my new 456 Carbon build but think they could be too long as the geom feels too slack, I think it would run better with 140mm (trial and error I guess.
    Can these be reduced at all do you know?
    Thanks in advance
    stupot
    Yep,
    Check out the rockshox site, there are service guides on there. I currently have mine set at 130mm using 20mm spacer so guess you just need to try and find a 10mm spacer.
    BigBoyXC
    Cheers Stupot!
    Munqe-chick
    did you buy the forks new? Mine (bought new from merlin) came with spacers in a plastic bag (despite obviously being OE as they came in a generic box not an RS box).
    BigBoyXC
    No I didn’t, they were fitted to a Cannondale I believe but the guy swapped them out after 4 weeks. They are as new but don’t come with these. I will put on the wanted page and see if I can get them from RS.
    Are they hard to fit / adjust?
    Cheers in advance
    mwleeds
    Just let the air out and put in back starting with the negative. You’ll be able to reduce them down to 140mm quite easily.
The topic ‘Can I reduce travel on a pair of 2010 RS Rev's Dual Air?’ is closed to new replies.
