Viewing 6 posts - 1 through 6 (of 6 total)
  • Can I fix my PIR light to stay on all the time like a normal light?
  • choppersquad
    I’ve got a PIR light on my garage which has stopped working, so I’m presuming the PIR sensor is knackered. Is there anything I can do to it to make it stay on all the time when it’s plugged in?
    squirrelking
    It may have a timer dial on the back, just wind it all the way out if so. Otherwise just rewire it.
    breadcrumb
    Usually if you switch it on then off, then back on again it stays on.
    stumpyjon
    Take it apart and bypass the the pir.
    spooky_b329
    Google it… A quick off-on-off-on or similar often bypasses the PIR and will make the light stay on permanently until dawn or when you switch it back off.
    steveh
    The one on my house did the same, I spent a while fiddling with it and the on off, on off, on off thing worked on mine sometimes. In the end 6quid at wickes for a new non pir light seemed worthwhile!
The topic ‘Can I fix my PIR light to stay on all the time like a normal light?’ is closed to new replies.
