Viewing 19 posts - 1 through 19 (of 19 total)
  • Campag cassette with shimano rear mech and shifters does it work ?
  • bladder
    Got a wheel that has a campag 9 speed cassette will it work with a 9 speed shimano set up ?
    crazy-legs
    Not really, the gaps between sprockets are ever so slightly different. You’ll probably get it working OK over most of the range with a jump or two somewhere but it’ll never be as good as full Shimano or full Campag setup.
    Margin-Walker
    no it doesnt work properly
    bladder
    I thanks for that Crazylegs I thought there was a slight difference with the spacing between the cogs cheers Bladder.
    Edric64
    Can you take some spacers from an old Shimano cassette and use them?
    Margin-Walker
    what about the top few sprockets that are mounted on carrier ???
    cynic-al
    I use the opposite system on my “good” road bike. Works fine IMO.
    IIRC there is a page on the CTC website with all the cross compatible options (eg on my other road bike i use 9s ergo, shimano mech and 8s cassette whch works ok)
    Edric depends on cog thickness.
    Edric64
    how are they joined? .I only have Campag 8 speed .Are they held with rivets that can be ground off?
    crazy-legs
    Why? ❓ 🙄
    saladdodger
    I have run campag 9 speed mechs and ergo shifters on a Shimano cassettee and I hate to say it but it ran alot smoother than a all campag set up I know there is a differance in the cog spacing but it worked realy well
    Just try it what have you got to loose
    foxyrider
    I have an old campag 8 speed and they are all separate sprockets and spacers.
    clubber
    Yes it works but it’s a bit clunky (have set up a couple of bikes this way)
    Campags 10s ergo and shimano mechs/9 sp cassette on my cx (hubbub fix for the mech) which works perfectly.
    dobo
    i use similar to clubber but my new rear mech wont play ball, but my old 8 speed mech worked perfect with 9 speed cassette!! but weighed a ton
    Margin-Walker
    tried to bodge a set up as per OP’s post on a cX bike and couldnt get it to work.STI and campy cass.
    Macavity
    There is some info on indexing and spacing of sprockets here:
    http://www.highpath.net/
    Cycle information
    Rear derailleurs + indexing
    and stuff about Marchisio sprockets.
    kilo
    crazy-legs – Member
    Why?
    I ran Campag 10 shifters with an 8 speed dura ace rear mech – why? – because Campag shifters were about £40 and the cheapest shimano STI’s at the time were about £120.
    cynic-al
    crazy-legs – Member
    Why?
    Cheaper, lighter, allow you to run bar-bag DUHHHHHHH! 🙄 😉
    clubber
    Pretty much all the info you’ll need here including the hubbub fix I mentioned:
    http://www.ctc.org.uk/desktopdefault.aspx?tabid=3946
    Jerome
    9speed shimano cassette with campag ergo here. Works fine. I have a mavin m9 cassette somewhere that is supposed to be a solution..
The topic ‘Campag cassette with shimano rear mech and shifters does it work ?’ is closed to new replies.
