Read all about it.. Read all about it.. STW in ‘chemicals cannot be absorbed through skin’ Shocker.
I guess I had better throw away any topical anaesthetic I have, including ibuprofen gel as well as deep heat etc, and might as well dip my hands in a bucket of liquid LSD, I am sure it will be fine.
1st google result. I think Canadians work the same as us, could be wrong though.
“How does a chemical enter my body through the skin?
Chemicals which pass through the skin are nearly always in liquid form. Solid chemicals and gases or vapours do not generally pass through the skin unless they are first dissolved in moisture on the skin’s surface.
The skin is the second most common route by which occupational chemicals enter the body. It consists essentially of two layers, a thin, outermost layer called the epidermis and a much thicker underlayer called the dermis. The epidermis consists of several layers of flat, rather tightly-packed cells which form a barrier against infections, water, and some chemicals. This barrier is the external part of the epidermis. It is called the keratin layer, and is largely responsible for resisting water entry into the body. It can also resist weak acids but is much less effective against organic and some inorganic chemicals. The keratin layer contains fat and fat- like substances which readily absorb chemicals which are solvents for fat, oil, and grease.”
