You can scale photoscan, you just need GCPs recorded accurately (rtk GPS etc).
Or you can introduce something with scale and scale off that, or manually measure GCPs. Different results depending on what you’re capturing and how the accuracy matters for you.
You can load into mesh lab say and you have a scaled point cloud then go from there.
TBH depending what you’re doing you’re better off hiring a Faro or similar, or doing something with RGB-D.
If you’re not familiar with PS, key thing is a) RAM b) RAM c) MORE RAM. And also a decent-ish GPU.
Can’t really say more than the above, as i’m dangerously close to giving away professional advice for free 😉 IF you’re at all interested in robotic or autonomous survey though then we should talk…
EDIT: sorry when i’m talking about scaling it’s the pro version.
