I was considering buying this frame off a friend. However, when he stripped it down, he noticed that the cable housing had rubbed a gouge into the underside of the main pivot lug, next to the bottom bracket shell. Its hard to get a good measurement, but it looks like the gouge is 2-3mm at its deepest, whilst the lug is probably 9-10mm thick around the pivot bearing at that point. So approximately 25-30% through the lug at its deepest.
Currently there are no other issues and it would be easy to fill it in, re-locate the cable and prevent further damage. I’m sure it would be fine for a while, but there’s obviously an increased risk of the frame cracking around the pivot in future.
I showed these photos to a local carbon-frame repair shop and they recommended a fairly pricey repair to the gouge, with no guarantee that the frame around the pivot still won’t crack as a result. As for the manufacturer, I don’t particularly want to name names at the moment whilst my friend is still having a dialogue with them about warranty or repair options.
I’m interested to know what the STW carbon experts think. Superficial scratch that a strong frame can handle, or its only a matter of time until certain doom?
Even without that damage I wouldn’t buy that frame; it looks poorly-maintained, which would explain why the seller failed to spot the problem much earlier. What else is wrong with it?
Posted 7 years ago
Viewing 6 posts - 1 through 6 (of 6 total)
The topic ‘Cable rub in carbon frame – repairable?’ is closed to new replies.
