Can I run my cooker cable from the cooker control unit above counter directly down, then turn at 90 degress and run along to the connection point below counter (and behind the oven) and that count as the cable running in permitted zones?
There will always be an identifiable "accessory or switchgear" identifying the possibility of a cable, it's just the the wire goes from horizontal to vertical at the intersection of the two runs from each accessory.
The alternative is to run the 10mm cable back up the wall and then down again to the connection point behind the oven.
thanks in advance.
