Viewing 3 posts - 1 through 3 (of 3 total)
  • Cable routing help
  • MoseyMTB
    Is there a secific way/order that the front cabling should go?
    For example should the front gear cable sit above the rear or visa versa or is it just a case of as long as its short and neat its fine?
    Post pics of your cable routing if you like.
    nickc
    Shortest and neatest is fine, dry run the outer cable a couple of different ways to get a idea…
    bassspine
The topic ‘Cable routing help’ is closed to new replies.
