Due to hamfisted knobbery, I didn’t do up the little cable end thing on my KS and it is now reinforcing a fireroad on penhydd. Before I get on to Jungle for a replacement I just wondered if it’s a readily available thing? I can’t find anything suitable online but I might be looking in the wrong place… Any ideas?
It’s a little (5mm or thereabouts) black disc with a step in, and a 1.5mm grub screw which clamps the cable- as you can just see at teh end of the cable here:
(thus begins the process of replacing about 50% of my hardtail, as it all hit some critical fatigue point at bike park wales and disintegrated)
I used the internal metal clamp from a 13amp electrical chock block. Cut the plastic off and clamp the cable inside by doing up the screws. Works well but doesn’t look very polished…….
