The S/M/L sizing is all over the place – you need to look at the numbers* to get a true idea of the size:
According to the link above, the Large Bronson has shorter reach (428mm) than my Medium Process (435mm), a Small T130 (432mm) or a Small Aeris 145 (433mm).
The stack, at 594mm for both Medium and Large is 11mm less than the Medium Process (605mm), 5mm more than a Medium T130 (589mm), and between a Medium and a Medium/Long Aeris 145 (589mm / 599mm respectively).
Stand-over (733mm) is considerably higher than the Process (650mm in Medium) or even the Extra Large Aeris 145 (704mm), but is lower than the Small T130 (763mm).
Compare the reach and stack numbers from what you’ve been riding to those of the Bronson – those are the numbers that define how you fit on the bike – and if it *feels* right, then go for it! 🙂
*Caveat: the numbers for everything except the Bronson are from notes I made when bike buying a couple of months ago, so could be in error.
