• This topic has 9 replies, 9 voices, and was last updated 9 years ago by Yak.
Viewing 10 posts - 1 through 10 (of 10 total)
  • Buying a single ring NW – do i need special bolts?
  • tpbiker
    Seeing single ring specific crank bolts available…do i need these as they look to be about £13 quid for 4 small bolts ?
    likewise do i need thoses tab shims or are the just for neatness? ie…
    tabs
    FYI crank is 4 bolt sram x9 with an e13 30 tooth ring
    ta
    honourablegeorge
    moove do them cheaper with free post
    mintimperial
    You can usually just flip the back of the bolts around, this will allow them to tighten down on the chainring. Obviously looks a bit shonky but it does the job at a pinch.
    cp
    xherbivorex
    search ebay for “singlespeed chainring bolts”, there’s tons and tons starting at about a fiver for 5. all colours, Ti ones for around a tenner a set too.
    tpbiker
    thanks folks…do i need those tabs as well?
    BillOddie
    Unless…you’re buying a 30T ring that is actually threaded, you can just use the existing bolts, well half of them.
    munrobiker
    You would use either the tabs or the bolts I think.
    GHill
    No, either shorter bolts OR shims.
    EDIT: Damn, too slow.
    Yak
    e13 30 tooth ring
    don’t know about that ring, but the on-one ringmaster nw ring was so thick that regular bolts fitted perfectly.
    Unless you are in a hurry, get the ring then try regular bolts (the right way round) and if they are too big, then get some specific single ring bolts.
The topic ‘Buying a single ring NW – do i need special bolts?’ is closed to new replies.
