I’ve got a variety of BBs. On the road I’m still using an ergomo power meter that uses isis (my versions anyway) bottom bracket sensors. I also had a middleburn chainset with skf isis bottom bracket. As long as you find a quality bottom bracket (and the SKF one is in my experience) there is no reason why it shouldn’t last – its the quality of the bearing not the shape ofthe interface that matters. My issue with the middleburn/skf setup was the creaking – drove me potty. In the end I got rid of the lot – no idea which bit was at fault but countless strips and refittings never sorted the issue.
Isis and octalink have had their day imo – its all about the various external setups now. The only “old skool” set-up with a continued niche following is square taper so that’s the way I’d go in your position.
