Been doing some searching on the subject of fork issues as mine are misbehaving. The issue of burping the fork using a cable tie seems to come up mostly, but this seems only to be in reference to the issue of air leaking into the negative air chamber (?) the symptom of which is that the fork doesn’t fully extend – it sucks down. This doesn’t sound likethe problem I currently have which is not getting full travel out of my fork – about 120mm instead of 150mm, but I don’t seem to have the fork suckdown issue as my forks fully extend when the bike is unweighted.
I let all the air out of the fork last night to test I did have full movement of the fork, which I did, but I struggled to get all the air out of the fork – I had to press the valve in, let the air our, then pump the fork a few times, then press the valve in again and more air would come out. I had to repeat this a good 4 or 5 times to get all the air out to enable me to fully compress the fork. This doesn’t sound right to me. Then when pressurising the fork again I had to put about 160psi in it to get my usual 30% sag (I’m around the 93kg mark weight wise), which sounds a bit high (can’t remember how much I put in originally, I think around the 90 to 100 psi mark).
I was going to try the burping thing tonight as it seems like it can’t do any harm and might work. The forks are due a service, but I’ve a few rides to do before I send them off. They’re not un-rideable right now, but do feel a bit squidgy and I’m worried about a total failure.
Any help to enlighten me on the inner workings would be appreciated. The fix is probably “It’s overdue a good service” but I’d like to limp them on for a few more rides before that.
Cheers.
EDIT: by the way the forks are Pikes, dual position of around a 2014 vintage.
