• This topic has 3 replies, 3 voices, and was last updated 13 years ago by Sum.
Viewing 4 posts - 1 through 4 (of 4 total)
  • Building wheels with used hubs
  • D0NK
    Rebuilding my rear wheel, the flange/spoke holes are slightly deformed from the previous build so do I reuse the same holes as before ie spokes inside/outside the wheels the same formation as before
    OR use the alternate spoke holes so spokes are poulling against a non deformed section of the spoke hole/flange?
    I was going to do the latter – use alternate config, but I put the first spoke in and it doesn't seat too well, will it 'pop' into place under tension or should I go back to original configuration?
    holyhutzpa
    Supposedly you should reuse existing notches…
    clubber
    I would always reuse the hub in the same way. They can creak if built the other way though I doubt it actually makes any functional difference.
    Sum
    I would reuse the rim in the same way as before too.
The topic ‘Building wheels with used hubs’ is closed to new replies.
