My Mrs currently uses my old Chameleon. I’ve got an FS frame on the way for her so I fancy using some spare bits to turn it into a winter bike to save my nice one.
Crazy idea as follows…..
Use spares lying about to build said Chameleon into a single speed but whack a 29er wheel on the front with rigid forks.
If this isn’t a fundamentally flawed idea, and bearing in mind the turn of the century geometry, if I was running discs would a 29er wheel fit into a modern 26 rigid fork that was probably suspension corrected and therefore a tad taller than necessary? I’m reasoning that the Chameleon was probably designed with a 100mm ish fork in mind so a shorter fork with a taller wheel might even things out?
No doubt there is a technical reason I’ve overlooked, aside from the fact it might ride like a bag of shite.
Suggestions welcome, just go easy…. 😉
