I have new door and windows for back of the house arriving, single storey 1980’s extension to a 1970’s house. Very rough render/harled finish externally, solid plaster internal.
As part of the work I am moving a stud wall internally, and this will reduce the back door from 2.6m width of sliding door to 1.6m of french doors.
The existing wall appears to be solid blockwork – I have taken off some render, and can see solid block at front, past frame and pick it up again internally as solid.
280mm in total for wall depth. 10/15mm of render and 10/15mm of plaster internally. This suggests a 250mm depth block.
I plan on infilling the 1m wide x 2m high gap left by reducing door size. I am concerned that the render needs to be on similar substrate to prevent cracking, and that he thermal properties are pretty crap!
My suggestion is still 250mm, solid wall blocks, but use modern light/thermal blocks, and add internal insulation via an insulated plasterboard straight onto said solid wall.
Thoughts and issues I may have missed?
Just to make things awkward, 1m beyond the door the other way the wall construction changes to 1990’s timber frame cavity wall….
