Hello all, I have a small worry with next door. We’re building an extension out to party wall (victorian terrace) at the back. Next door are doing the same build in a couple of months so we agreed party wall agreement not an issue. Party wall used to be large garden wall and part lean to outhouse on each side. Next door thought it needed rebuilding as there was damp in the lean to part on both sides.
My builder thinks its fine to build on with tanking/dry proofing but mortar is a bit crumbly so neighbours still think it needs rebuilding. My side has been re-mortared where need be, tanked, rendered with tanking render and ready to go. Next door are still worried that tanking isn’t enough and the middle of the wall may remain moist if tanking both sides.
All build is going through building regs and within the law.
My question… does a wall dry out from the inside if you tank both sides and top is sealed (no rising damp). Are my neighbours too concerned with what they can see now before the lads are anywhere near finishing? Who should relax, me or them?
