• This topic has 16 replies, 11 voices, and was last updated 10 years ago by pdw.
Viewing 17 posts - 1 through 17 (of 17 total)
  • Buffering.
  • zippykona
    For our sins we are listening to Christmas radio in the shop via the net.
    Then it disappears due to buffering. The really crap station is obviously ok.
    So whose fault is buffering? Bt or the people supplying the radio station?
    Cougar
    My car’s not running properly. What’s the fault?
    Could be a dozen things. What’s your internet connection like generally? Are there other devices using the connection? Can you lower the stream quality? Is your PC busy? Have you rebooted the router in the last five years? Do other videos / audio stream ok? Is there another PC / phone you can try? Does it use Flash, if so are you on the latest version?
    zippykona
    Its the only thing running on the iPad. Internet is normally fine.
    I’m assuming the router is the by box that sends the WiFi. Never rebooted it ,didn’t know you needed to do stuff with it.
    Imagine you were explaining stuff to a very bouncy spaniel and you are close to my level.
    clubber
    If you can stream other music ok then it’s the christmas radio station.
    Try Tunein radio online and if that works, you’ve found the problem.
    If it’s not that then it could be one of a million things.
    maccruiskeen
    Have you tried turning it of and on again?
    zippykona
    We are using Tune In and everything is really rubbish now and we’ve had to go back to normal radio. Result!
    It all worked fine at home so its probably shop related.
    zippykona
    So it was fine yesterday and bloody awful today.
    Checked the internet speed is 19 MBS (or whatever it is) much?
    Stoner
    Would you consider my 12″ penis a bit much?
    *shakes head at people flaunting their net speed. kicks hamster powered router*
    zippykona
    I’ll take that as a no then!
    bruneep
    Ahh sir was blessed with the extra small limited edition version. 😉
    wwaswas
    well I wouldn’t use it as a rule.
    Stoner
    I actually asked for a diminutive harpsichordist…
    fasthaggis
    Buffering
    zippykona
    Finally gave up on songs stopping half way through and have amped up my phone.
    Running on 3G we get non stop ,no buffering music.
    Can my 3G really be better than BT internet?
    takisawa2
    Aaarghh… 😉
    Listening to the internet radio eh… 😉
    pdw
    3G really shouldn’t be faster, but it’s possible. It’s also possible that it’s dropping to lower bitrate because it’s on a mobile connection.
    Are you trying the same station in both cases?
    Have you tried using the iPad when it’s right next to your wireless router? Streaming audio and video is particularly sensitive to a borderline wireless connection.
    It’s also possible that there’s a network problem between BT and the source of radio station. Just because you get 19Mbps to a speed test site, doesn’t mean that you can get 19Mbps to everywhere else on the internet.
    “Buffering” is just the process of loading up the next few seconds of audio so that the music can carry on playing through minor network interruptions. If the data is arriving at your ipad slower than it’s being played then the music has to stop whilst it refills the buffer.
The topic ‘Buffering.’ is closed to new replies.
