Viewing 31 posts - 1 through 31 (of 31 total)
  • Budget uppy-downy seaty-posty
  • Cougar
    So,
    I’ve been idly toying with the idea of a dropper seatpost. I’ve kept half an eye on discussions here, and recommendations all seem to be for expensive solutions that are, for my mincing luddite purposes, over engineered.
    I’m not racing and am quite happy to stop mid-ride to admire the view, take photographs, eat jelly babies, or find other excuses to cover up the fact that I’m cream crackered. I don’t really want, or need, pneumatic hydraulic spring-loaded cleverness, or remote control or anything. I’m really just looking for something where I can get the saddle out of the way and then later return it to the same position, it doesn’t have to be much more advanced than a regular QR.
    Does such a thing exist even, or were they rendered obsolete years ago and I’m going to have to pony up a three-figure sum for a bloody seat-post (or more likely, do without)?
    muzzle
    A regular QR…? Sorry to be a smartarse, but what more do you need it to do?
    tmb467
    Ghetto Post
    This got slated on here a while back but it might suit your needs
    svalgis
    Standard seatpost with markings?
    avdave2
    It was called the Hite-Rite. 🙂
    cookeaa
    QR and a bit of bailing twine/string?
    You tie the string between the seat rails and the frame so that at full height it is taught, just to make it easier to find your preferred full height position each time.
    The QR provides you “infinite adjustment” of seat height…
    Or look at a “forza” post.
    Cougar
    The QR is ‘effort’ to open and close, I’d prefer a button or lever or something (MTFU, I know). And getting the saddle back to the right place is a bit of faff, post markings wear off and it’s a bit of a fiddle to align. First world problems I know, it’s not a huge issue, just figured “click” – up / “click” – down would be a lot quicker and simpler.
    Cougar
    Oh, and,
    How do I know which of the 47 different post diameters I have, short of measuring? Is one “standard” more standard than the others or anything?
    wwaswas
    those cheapy £75 ones (Forza??) seem to be ok as a toe in the water.
    Joplins etc come up cheap on here fairly regularly if you want to have a go for a bit and see if it works for you.
    [edit] seatpost size – take current seatpost out of frame, read size off bottom of seatpost, buy one that size.
    Cougar
    Ah, cunning. (-: Amusingly / pathetically, I’d never have thought of that. Ta.
    wwaswas
    they’re damn clever these engineering types, you know 😉
    RobHilton
    Buy cheap, buy twice.
    What you NEED is this bad-boy – check out the genital crushing power at around 1:40 in.
    [video]http://www.youtube.com/watch?v=WxZbizCz4es[/video]
    JoeG
    Christian
    Been using the forca post for a while on my hardtail and its done the job fine, bit industrial but works and easy to strip and clean, no brainer option imo.
    Have a giant dropper on full suss and infinate adjustment is great but was double the price of the forca.
    Cougar
    What do you know, that worked too. 30.9mm, apparently.
    Someone on another thread suggeted a TMARS post. At £65, that seems like a bargain to me. Two things:
    1) anyone any first-hand experience of them, and
    2) seems I’ll need a shim, and they come in aluminium and ‘thermoplastic’ (whatever the geoff that is). Any compelling reason to use one over the other, or does it make bugger all difference?
    burt
    cor that RAZE post me me wince, thats as near to an ejector seat as you’re gonna get.
    dantsw13
    Tmars/Forca/ICE V8, as a basic model will do you fine. You may need to disassemble the post for a greasing, but it’s pretty straightforward. As for a shim, I’d go Aluminium, just because its the same as the seatpost and seat tube, so less likely to produce issues.
    tomhoward
    That rase one wouldn’t be so, lets say, punchy if you were sat on it and let your weight dampen it. Sold out though 🙁
    seavers
    I started with a 75 Quid one and to be honest it was more of a hindrance. While the basic mechanics were good the lever was horrible. The whole point is getting the seat out of the way and then back with no fuss. The variant I had was just awkward and impossible to use quickly.
    Sold it and went for a Gravity Dropper Turbo. Yes they are expensive but they are fit and forget. In addition it just works, it works well and it works quickly. If it is something you are going to use it is a fantastic purchase.
    scaredypants
    I have one of those – and 2 bollocks still
    Sold out though
    rumoured to be a new version coming
    I quite like mine FWIW – if the new one has 2 saddle clamp bolts it’ll be good
    Me, and I’d recomend it highly
    Bugger all.
    richmtbguru
    Buy cheap, pay twice! I would highly recommend the reverb! I’m a trained bike mechanic and I’ve stripped these down can say that these are a top quality product.
    patriotpro
    How much are those Rase? Does anyone own one?
    tomhoward
    According to rase, around £220 but not sure if that’s inc import duty.
    smatkins1
    I saw a CB Joplin go for £30 today on eBay. They are known for having a lot of lateral play and this was a lever operated one… but still… £30!!!! times that by about 10 for a reverb!
    tomhoward
    I’d never buy a cb product without a warranty. And even then, I’d buy the reverb before a Joplin. And I did.
    gonzy
    try the Ice Lift V8…its supposed to be pretty good and cheap (£120) compared to the others
    dantsw13
    ICE V8 through purebike.fr was £87. With Euro warranty.
    Sui
    If you stay with a solid post, then ROOX ones with markings are very good, never wore when i had one- pretty too. Unfortunately i snapped mine many moons ago giving myself a lessen in self disection..
    nickc
    Thing is, I know my current ride locations and routes, and riding as I do in the chilterns, where its all gently flowing hills and no one breaks into anything as perverse or demeaning as a sweat, I don’t need a dropper. When I go to the parts of the world where one might benefit from getting he saddle out of the way, I like to stop and pause and have a good look at what I’m getting into, so QRs are a perfect excuse for that.
    I’m probably doing it wrong though…
The topic ‘Budget uppy-downy seaty-posty’ is closed to new replies.
