Do you have any spacers above your stem?
If so, could you rotate the bars so the upsweep is backsweep and raise the stem above the spacers?
No, I’ve already moved my stem above the spacers. Did think about using upsweep as backsweep but think it might look and feel a little odd.
Usually something will come up within a few days that you didn’t realise you needed!
Thanks, I already check that site regularly.
Have a look at brand x bars on chainreacion. Only £16 but proper brand and backup. Choice of rise too.
I looked at these but although it states the upsweep is only 5degrees the pictures seem to show quite a pronounced diagonal sweep from the centre to the ends like my current Vitus ones which look a bit odd on the bike.
I have some 760mm low rise black Whyte bars in VGC – 7 rides old if you’re interested
Thanks but looking for medium rise 20-30mm. I think I might try those ebay ones for £10.
