I’ve got a rider 50 – is that the same thing
It’s fine as a slightly posh speedometer, which is all I use it for although it’ll record your strava segments if you want. (I find it less accurate than the phone app for that)
I have mine set just to show speed in the top half of the screen and time plus direction in the bottom 2 quarters
I’ve never used any other gps so can’t compare to anything else but it’s OK. A bit slow to get a lock initially (so turn it on and put outside while you’re getting ready) and every now & then it flattens its battery between rides, I think by not switching off fully (the buttons are quite fiddly)
