Hi all,
I’ve got an old set of Hope X4 brakes that I was trying to fit today. I think I’m right in saying that these use 6mm hoses. Anyway, the first problem was that the front hose was too short. Ok so I need a new hose, but nobody seems to stock 6mm hoses anymore. The second problem is that (in a ham fisted attempt to remove the old hose at the caliber) I wiggled the hose a bit much and broke off the little tube that comes out of the 90 degree connector and fits into the hose.
So, my questions are: what parts do I need and where can I get them.
Can I source some 6mm hose and replace the 90 degree connector (or even just that little bit that sticks out the end)?
I could upgrade to a 5mm hose I guess, but then I need 2 new 90 degree connectors as well (as the X4 has 90 degree connectors on each end of the hose for the front brake).
Anyway, thanks in anticipation.
Andy
