Viewing 9 posts - 1 through 9 (of 9 total)
  • broken chains and chain tools
  • spudly1979
    hi, chain broke again today, and after promising myself after the last time, i’m going to actually buy a damn chain tool for my bag!
    Any suggestions on a good one? I’ve bought cheap before on tools, and regretted it, so i’m after a decent (but not ridiculously priced!) one for my bag.
    Also – at what point would you recommend changing the cassette when i change my chain? I’m going to have to get a new chain, but my cassette is only new from september, so do i need a new one too?
    nealy
    spudly1979
    thanks Nealy, ordered the superstar one, i am so not getting caught out and having to walk home again!
    Any advice on the cassette from anyone?
    TandemJeremy
    Teh only way is to try it – cahin only a bit worn you might get away with it – chain very worn – you won’t
    spudly1979
    thanks TJ, just had bike serviced and was advised chain was in good nick (apart from breaking…) so hopefully can sort without buying a new cassette.
    Had thought of trying to repair with a powerlink thingy – but is this only for temp repairs to get you home, rather than a more permanent repair?
    thomthumb
    powerlinks can be permanent – no trouble.
    chains don’t tend to just break – what are you doing with it?
    spudly1979
    i know, trying to find what i’m doing wrong. I’ve not crossing over the gears, as i learned relatively early thats a good way to break a chain!
    I broke it over at cannock, think i just tried to change both front and back mechs at once, and it got caught. Helpful passer by had a chain tool so removed a link and sorted it – but left it then and i’m thinking that would have weakened it? It went again today as i was going downhill, so not too much tension on chain, and no gear changing? Could it have been over tensioned as my rear sus moved?
    bikewhisperer
    possibly a bent tooth on a chainring.
    I’d always rejoin a chain with a powerlink, or a new pin with shimano. It’s not worth the bother of it breaking again.
    Northwind
    If it’s for your bag, what you want is a Topeak Hexus- it’s one of the best multitools out there and has a chain tool that’s better than most expensive workshop tools.
    Cassette- what you should do is replace the chain before it’s too worn, that way the cassette is likely to take a new chain. But at this point, what you do is you fire on a new chain and hope it works, you’ll soon know if it doesn’t.
The topic ‘broken chains and chain tools’ is closed to new replies.
