This might not be relevant BUT, have you had the shock off at any time? i mentioned this on here in a previous thread, I’ve noticed that if i put my shock back on and tighten up one bolt either upper or lower it doesn’t matter which then put the other one in and tighten up fully it pulls the rear end out of line.
I’ve done this twice. First time i sent the rear shock off because it failed. Got it back and wound in as above and the shaft was smacking the inside of the air can which inside looked like a plenishing bowl.
I’m just thinking that if its been off and not tightened up steadily a tad at a time then maybe?
Either way looks like a New Frame.
