Re Sync Rate: Even if I swap around the download speeds are around 1mb with the filtered faceplate and 4.5mb with the micro filter. I then swao back and they are similar.
From the router settings:
ADSL LineStats:
4.5 mb download speed:
Downstream 4590 kbps
Upstream 888 kbps
Noise margin Down 6.3db / UP 9.7db
Line attenuation Down 46.5 db / up 28.4 db
Output power Down 0 / up 12.8 db
1.00mb down load speed
Downstream 1386 kbps
Upstream 888 kbps
Noise margin Down 7.5 db / UP 8.7db
Line attenuation Down 45 db / up 28.2 db
Output power Down 0 / up 12.9 db
My line attenuation seems high. What does that mean?
I am going to try a different filtered face plate and see what happens.
