- This topic has 713 replies, 3 voices, and was last updated 6 years ago by yourguitarhero.
Brewers of STW
peterfileFree Member
For the beer/DIY geeks…I’ve attached a screenshot of my home made Brewpi.
Basically, my fermenting fridge is not at my house, so being able to monitor and control it remotely was a bit of a challenge.
I put together a brewpi, which lets me monitor temps and control both the heating and cooling elements in the fridge. I had to remove the internal thermostat in the fridge to allow for crash cooling.
I also hooked up a webcam so that I can check krausen etc. I originally tried to get a webcam working with an IR LED array, but it just wasn’t working at all. So instead I bought a regular LED USB light and hacked the cable, sticking in a relay and hooking it up to the pins on the Pi. I then wrote a bit of script that turns the light on, takes a photo, then turns the light back off. Works well!
Beer temp is measured through a thermowell, so is the actual temp of the fermenting beer. I can keep the beer within 0.1 degree. The fridge has it’s own sensor to let the PID do its thing, then I installed a third sensor to keep track of temp in the outhouse, mainly to make sure the 60w heater I have in there will be sufficient as winter approaches.
It’s all completely automatic now, I don’t lift a finger other than to adjust the profile.
I originally had it hooked up to a mifi device, but it wasn’t very reliable, so I’m not poaching my mum’s internet connection through a couple of powerlines and it has been faultless.
NZColFull Member*appluads* As someone who escalated from 10ltrs to 1600 I applaud your escalation of tech !
ClobberFree MemberThat is legend!!! Want,
Can you do me one, I’m currently looking for a fridge…
peterfileFree MemberClobber, cost wise you’d be looking at:
Raspberrypi = £20
Arduino Uno = £10
Relay board = £5
4.7k resistor = £0.01
DS18B20 sensors (min 2) =£8 total
Thermowell = £10
Wifi dongle = £10 (subtract if you can use ethernet)
Total = £63I’ll assume you have a spare SD card, power supply and a couple of USB cables, along with a couple of sockets and wire (I used old extension cables).
A 60w greenhouse heater will set you back about £10. If you want to add a webcam and light for taking photos, add another £7 total. You might want to add a case for the pi etc, but I just use tupperware tubs.
So you’re looking at about £60 for full automation and/or control of your fermentation. Not bad!
I’d consider doing another, but flat out at work at the moment. In all honesty though, you’d enjoy doing it yourself. I’d never done any of the stuff needed to put it together, but with only a couple of head scratching moments I managed to get it done in an evening.
Excellent guide here.
peterfileFree MemberI’m not sure. I used the old style Pi (i.e. not a Pi 2) and it runs perfectly.
thisisnotaspoonFree MemberInteresting how different people escalate in completely different ways.
I’m planning a cut price (eBay/China) version of the electric brewery which with upgraded relays would happily run a comercial brewery. Everything pumped, controlled etc. Then connecting it upto some 6 gallon PP buckets. Why? Because Im a process engineer and like the idea of dumping in a few kg’s of grain at one end and not touching it untill beer comes out the other 😀
peterfileFree MemberTINAS, you could be in luck…there’s a guy on ebay at the moment who is trying to sell an aborted build of the panel (he bought all the parts but didn’t put it together). I wouldn’t be surprised if he would take an offer, it’s be relisted a couple of times.
thisisnotaspoonFree MemberTempting, although his price is over double what I’d budgeted. Although he has used a lot of probably better quality bits than i’d been intending to. Might need to sit down with a spreadsheet and do some maths.
thisisnotaspoonFree MemberAntique geekiness on the topic of forced carbonation.
http://onlinelibrary.wiley.com/doi/10.1002/j.2050-0416.1925.tb04942.x/pdf
Summary for anyone struggling with long sentences:
Forced carbing is fine, and if done cleanly with a carbonation stone (they’re experimenting with assorted pipes wrapped in cloth, but ultimately it’s the same apparatus) produces a very stable beer, very quickly. It also covers the advantage Peterfile mentioned, that it works well not just for carbonation but for eliminating contact between fermented beer and air.
But it doesn’t mimic secondary fermentation. Unfiltered, or secondary fermented beer is better in every way apart from clarity, but they accept this won’t work commercially as people have grown up to expect completely clear beer.
The exception is in particularly dry styles where forced carbonation gives a dryer palette (or rather it’s natural carbonation, or brewery gas that imparts a fuller/sweeter flavor).
peterfileFree MemberOn a homebrew level, you tend not to filter anyway, so it’s entirely possible to achieve the same benefits of conditioning when you transfer to the keg.
I’ve got a saison currently conditioning at room temp in the keg, which I’ll then drop to about 1 degree when it’s ready, fine it and then force carb it. So perfectly conditioned, perfectly carbed and perfectly clear!
troutFree MemberRaffle here for a home brew setup
http://www.jimsbeerkit.co.uk/forum/viewtopic.php?f=6&t=74000only a fiver a pop
Thought Saisons were supposed to be a little cloudy ?
peterfileFree MemberThey are, but this one has been brewed for someone and they wanted it clear! No telling some people 🙂
Gelatin is fab for when you’re planning on handing the beer out since there’s no sediment or haze (other than occasional chill haze), so it tends to get better reactions for regular beer drinkers who, as TINAS says, seem to think clarity means a better beer.
thisisnotaspoonFree MemberI’ve got a saison currently conditioning at room temp in the keg, which I’ll then drop to about 1 degree when it’s ready, fine it and then force carb it. So perfectly conditioned, perfectly carbed and perfectly clear!
When you say conditioning in the keg, do you mean you’ve transferred from primary to a keg (with some yeast still in suspension), added sugar for a secondary, and now you’re going to clear it and transfer it to a ‘clean’ keg (or bottles)?
peterfileFree MemberIt’s worth having a read at the end of Section of of Chris White’s “Yeast” if you can get your hands on it (great book), specifically the sections on bottle conditioning and cask conditioning.
For bottle conditioning, the benefit is cited as the scavenging of oxygen (a problem for small scale breweries and home brewers). Disadvantages are results that vary, sediment, potential autolytic destruction of yeast cells releasing unpleasant flavours.
Secondary fermentation/bottle conditioning generally does not contribute any flavour, it simply adds co2.
For cask conditioning things are slightly different. When talking about casks, the term conditioning does not mean the same as condition. In this sense conditioning means the maturation process (rather than just the addition of co2).
I transfer from primary to the keg without filtering, so plenty of yeast still in suspension. I then leave to “mature” at whatever temp suits the yeast/beer (i.e. my focus here is allowing the beer to develop rather than carbonate). Some beers don’t benefit from any maturation (e.g. a pale ale), but something like a robust porter does well sitting at cellar temps for a couple of months. I prefer to do it in the keg rather than a fermenter because I it’s less oxygen permeable, easier to store and move around and I can immediately hook up to carb and serve.
When I’m happy that the beer has reached peak flavour, I crash cool and fine with gelatin in the same keg. Then the first pint I pull is filled with all the gloopy yeast and sediment that the gelatin has dropped out. After that it’s all good 🙂
thisisnotaspoonFree MemberAhh now I understand.
I think I’m going to need a bigger circle of beer drinking friends and more kegs!
peterfileFree MemberYou’d be amazed at how quickly your beer goes once people (colleagues, friends, neighbour) hear that you’re handing out free beer!
It’s the same effort to brew 2 litre or 20 litres and the cost difference isn’t much, so I prefer brewing more and giving more away.
My drinking has stayed pretty much the same throughout my brewing adventures…usually zero through the week and then 8 beers spread between Friday to Sunday. So I’ve got a lot to give away!
The irish place I get my kegs from does them super cheap whenever they get a container in. Works out at around £27 a keg including delivery.
thisisnotaspoonFree MemberThe irish place I get my kegs from does them super cheap whenever they get a container in. Works out at around £27 a keg including delivery.
Thehomebrewstore.ie were doing them for £90 for 3 plus postage if that’s where you mean?
We probably have a half with dinner most evenings and a couple of pints at the weekend.
My only worry with kegs is keeping lines clean etc. Fine in the summer for BBQ’s etc, not so useful if the lines need cleaning every other pint over the winter. Have you tried those taps that mount onto the disconnect? I presume you could pour a pint from any keg and then have a keg of star-san to flush out the tap afterwards.
peterfileFree MemberPF, Group buy on kegs from your Irish Place?
It’s easier just buying separately, since their postage is actually surprisingly cheap (much cheaper than it would cost to bring in loads and then send them out to each other here).
That’s the one. I preordered and got them for 33 euro each I think?
I had the same concerns. The way I’ve dealt with it for now is easy…I don’t actually drink any beer “on-site”, so have to take it all away with me, so taps were a bit pointless.
Instead, I’ve got a cobra/picnic tap attached to beerline and a disconnect. I simply fill up bottles from that to take away with me. A beergun is on the xmas list. I purge the growler of o2 first.
When I’m done filling from one keg, I put the disconnect on a keg I keep full of starsan and give it a squirt (as you mentioned), which cleans out all the previous beer, then I just move on to the next keg and fill.
scaledFree MemberHow does that look for a shopping list?
I’ve already got a raspberry Pi (and a spare fridge). Would I need a thermowell if the probes are waterproof? I’m assuming I would as they’d be a bugger to keep clean without.
peterfileFree MemberLooks good scaled.
I’d definitely go for a thermowell. It also means if you need to move the carboy you can just pull out the probe.
I would suggest getting longer probes if you want to have your pi/arduino anywhere other than right beside the the fridge.
Also, pick up some jumper cables. I’ve got some spare if you want me to send over a few.
Are you connecting via ethernet? If you want to use wifi you’ll need a dongle.
Once you’ve got the basics set up, let me know and I’ll direct you to some other scripts which are really handy (like auto reboot when connection lost etc). I’m not sure how computer literate you are, but you’ll probably want to set up dynamic dns to ensure you can always get to the webserver (quick and free, but requires an additional script on the pi and a bit of setting up)
Any problems or queries, give me a shout. It’s quite straight forward, but not without challenges. In particular, you’ll need to work out the colour coding on your probe…they’re all different! Google is your friend here.
Oh, also…are you planning on connecting a socket to the relay and then just plugging the fridge into that? If so, rip out the thermostat on the fridge and bypass it completely by connecting the wires that previously went through the stat. 2 minute job, but absolutely essential if you want to cold crash or lager (which is one of the best bits of having a dedicated fermenting fridge with full control!)
scaledFree MemberYeah, i was going to have the heater and the compressor running off the relay so i can cold crash before bottling, my crappy little bucket with a tap in the fridge, do all the fermenting, cold crash (with gelatin from the sounds of it!) then bottle up once it’s done and do secondary in the bottle.
It’s a double fridge/freezer, i don’t see why with therm controlled heating/cooling the freezer section shouldn’t work as well, the algorithm should just learn to blast the cold for a shorter length of time. For starters i’ll probably just bang another heater in there and use that for some wine.
For me the Pi bit will probably be the easiest, compared to the shite that i have to work with all day…
UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
UI[10]=&Close
FriendlyEventName=Stopped workinggobuchulFree Memberdouble fridge/freezer, i don’t see why with therm controlled heating/cooling the freezer section shouldn’t work as well, the algorithm should just learn to blast the cold for a shorter length of time
Not sure how this would work? Am I missing something?
The cooling circuit and compressor is common. So when the fridge temperature is above your setpoint it will kick the compressor in.
Unless you intend to just run the freezer at a lower temperature and have the main fridge take priority?
scaledFree MemberI think it’ll depend on the way the cooling is configured, i’ll have a good look at the weekend.
I know that there’s a fan in both the fridge and the freezer so i’m hoping that it’s an evap unit with two independent cooling circuits off a common compressor. I know that’s how Mille do it, but i’m not going to butcher one of those 😛
If not then i’ll have to have two heating chambers and a manual (cold) crash override
ransosFree MemberDoes anyone have advice on corking wine bottles? I tried using a twin lever corker, straight uncoated corks (grade 2 apparently), but they will not go all the way in, regardless of the pressure applied. Corks were tried both soaked in sanitising solution and dry, it made no difference – about 1/4 of the cork would remain out of the bottle.
I see that you can buy coated corks – do they go in easier?
myopicFree MemberA rather ignominious first post on the brewing thread 🙁
Brewed up a gallon of IPA today, my second ever batch. Mashed in OK, mashed out OK, Sparge fine, did the boil, added the hops, put the brew pot in ice bath to cool and when I went to check the temperature, noticed weird reading. Then noticed that this was because the thermometer had broken. It had broken before I put it into the brew, so hardly any contamination – maybe one small drop of red dye on the surface. Filtering it into the demijohn seems to have removed it.
2 questions:
1. worth carrying on, or bin the lot? I can’t smell it off the mix that is in the demijohn (see below).
2. Answer to 1 may depend what it was. It was a food thermometer, but I’m unsure what the fluid is (or was..). I don’t think it was ethanol as it floated in top of the water and had a slight smell, reminiscent of paraffin.So advice please. Many thanks 🙂
thisisnotaspoonFree MemberProbably fine, it’s not mercury.
Amazed you could smell it over an IPA TBH, not enough hops!
myopicFree MemberI have a good nose (I’m a chemist) so could pick up the odour in the kitchen after it broke, despite the hops. Definitely not ethanol (and I knew it wasn’t mercury! 😉 ) Other option was paraffin, which I was wild about drinking but its such a tiny amount and I think its probably trapped in the filtrate that I’ve gone ahead.
Will play it safe and let Mrs M try it first when it comes round to drinking 😆
thisisnotaspoonFree MemberMy cousins a circus act (and a stuntman), so he get’s to gargle paraffin for a living, and he’s not dead yet, although it’s only a matter of time.
myopicFree MemberThanks for the feedback guys. Will report back in due course on palatability (or otherwise)
yourguitarheroFree MemberWell, my brewing has been coming along nicely.
Got the Grainfather to brew in, built a temperature controlled fermentation chamber with a chest freezer and a STC-1000 controller and got some cornie kegs powered by some old fire extinguishers.
Easy to keep the beer cool:
Also got Mikkeller’s beer book which has some great recipes in it.
Currently have a keg of Monk’s Brew (to which I added some Carafa III for more roast flavours) on the go. 19 litres of 10% dark Belgian ale – dangerous times!have some Czech pilsner lagering in the freezer at the moment, should be ready just in time for me and the boys’ annual Easter MTB piss up weekend in Dumfries
thisisnotaspoonFree MemberFree afternoon, discovered the local off licence sells home brew supplies, so dug out my kit from the loft, dusted off the removal van detritus, plumbed together all the bits that had been sat in a box for way too long and bought some of everything that the shop had (not much choice)!
Recipe:
1campden tablet
1 tsp gypsum(no idea what our water is like, but it’s Thames water, so it’ll knock your teeth out if you look at it’s pint – hard)
3kg Youngs Pale malt
500g Youngs Crystal malt30g Fuggles at 60min (First wort)
20g Goldings at 60 min (first wort)10g goldings at 15min
10g goldings at 0min (steep, cool and whirlpool).2 sachets of Youngs ale yeast.
Recipe is based on the Landlord clone, but adapted for what was available, and it’ll be a bit weaker. Which is fine by me, the fridge is full of 7% porters and IPA’s, I could do with something a bit more drinkable!
Shout out if you spot me doing something wrong or you think the recipe is going to end up undrinkable!
[url=https://flic.kr/p/F4e4Am]2016-03-20_03-47-36[/url] by thisisnotaspoon, on Flickr
Do as I say, not as I do! You wouldn’t think I work in health and safety would you?
[url=https://flic.kr/p/FnoUHe]2016-03-20_03-42-46[/url] by thisisnotaspoon, on Flickr
thisisnotaspoonFree MemberHe did the mash….
He did the
monstermash at 66.5CMissed it my 2C, so added another litre (making 10.5 in total) of boiled water.
[url=https://flic.kr/p/F4jYb1]2016-03-20_04-34-31[/url] by thisisnotaspoon, on Flickr
[url=https://flic.kr/p/F4k1Nf]2016-03-20_04-34-52[/url] by thisisnotaspoon, on Flickr
gobuchulFree MemberIt will definitely be a bit weaker! Though that may not be a bad thing!
A lot of crystal in that, might overpower everything else.
thisisnotaspoonFree MemberI’ll just deduct it from the sparge.
Brewsmith is saying 3.7% if I make 20l into the fermenter, which is about right, I want something that can be drunk on a school night rather than the fridge full of 7% porters and IPA’s I have at the moment 8)
thisisnotaspoonFree MemberMash done, turns out my tun needs more insulation, dropped to about 58C 🙁
Now mashing out at 76C
And built a cooler 8)
[url=https://flic.kr/p/Ey7t33]2016-03-20_05-34-45[/url] by thisisnotaspoon, on Flickr
Will tidy up the plumbing at some point, had intended to just bend the ends over and jubilie clip hose on, but they kept kinking so some brasswork was needed. Really a 10mm right angle to 1/2″ BSP female fitting, and a 1/2″ to barb is all that’s needed, but that’s not what was in the toolbox.
The topic ‘Brewers of STW’ is closed to new replies.
