Apologies if this has been covered i length already bit I searched on the forum and could not find answers to my questions.
I finally got the bottle to trim down my lengthy brake hoses at the weekend, and now I just need to bleed them. The rear brake pulls right back to the handlebar so I can only assume i got some air in the system, the front brake pulls about half way to the bar (as it did before I cut the hoses).
A few questions:
Should I bleed the front brake as it seems ok?
How do I check if my pads are worn? Both brakes pulled half way to the bars before trimming the cables, previous to this I did a long ride in the wet (very wet) and at the start of the ride I only had to pull the brakes about 10mm before they engaged. Does this mean I have worn my pads on my last ride?
If I need to replace the pads, then with what? The brakes are avid elixir CR's and I am not sure what they come with as stock, I also seem to have 3 OPTIONS, metal organic, organic or sintered?
cheers
