I had a similar problem with Hope mono minis, and in the course of events i’d changed frame,forks,headset,hub,rotor and caliper (I wasn’t specifically looking for the cause, just upgrading), and still had a judder.In the back of my mind,i’d always suspected the rotor, as the braking surface doesn’t comprise of two concentric circles,more a series of tapers between spokes(just like the Shimano centrelock rotors), so I thought i’d try a set of Shimano XT 6 bolt rotors(which have a concentric brake surface)and all traces of judder disappeared instantly.If you can borrow a wheel fitted with one, it’s certainly worth a go.
