Viewing 10 posts - 1 through 10 (of 10 total)
  • Brake fluid on my alloy wheels
  • molgrips
    Some of the paint has been stripped off. Is this worse than just cosmetic? Will bare alu corrode? Can I just clean it up and spray it myself?
    Cosmetics are not a consideration since the Prius has hubcaps/wheel trim on top of the alloys.
    jota180
    Yes but a regular polish will keeping it looking OK
    bearnecessities
    Sound like an engine/seats/dash out job to me. Chop chop, get to it.
    molgrips
    I could perhaps just polish it up and spray it with any old paint?
    andyl
    http://www.halfords.com/motoring/paints-body-repairs/specialist-decorative-paints/halfords-heavy-duty-pu-lacquer-500ml
    Of if it’s just a bit in a non-visible area then seal with some clear nail varnish if you are really worried.
    jota180
    Should do it if you can make a decent job
    Any corrosion won’t be structural just a bit rough to look at
    sharkbait
    I’d be more concerned about how the brake fluid got there. About £50 to strip and repaint a wheel (properly), may be worth while doing.
    molgrips
    It got there because the wheel was handy when I was using the Hope bleed kit to bleed the brakes on my bike 🙂
    cheekyboy
    You need to make a hot poultice from flat irn bru, fullers earth and Jam from a hipsters jar !
    Spread liberally and rub like a mad man.
    woodlikesbeer
    The alloy shouldn’t corrode any more provided the brake fluid is all removed. You can get wheels touched up for sensible money – or get the whole wheel resprayed for £50 (as said above)
The topic ‘Brake fluid on my alloy wheels’ is closed to new replies.
